Horzontal lines at corners with patterns
wraeththu
(@wraeththu)
I am having issues where there are horizontal lines showing up near corners/edges some of the time when printing repetitive patterns. I've tried slicing with classic, arachne, input shaping. It seems to occur every time. I tried tightening the belts, I loosened the belts, I eventually replaced the belts (because I had spares). I also tried slowing down the print to 70% speed and they are still there. The attached pictures are just a part of a larger print, but it occurs when turning the part on the print bed as well. So it doesn't seem constrained to the x or y axis. It seems to show up when printing repetitive patterns like brick work. It doesn't seem to be z banding and I am at a loss to when searching for similar issues to find a fix. Any insight is appreciated.
thank you
Dieses Thema wurde geändert Vor 2 years von wraeththu
Veröffentlicht : 24/04/2024 1:05 pm
