help with vase
tom
 tom
(@tom-27)
help with vase
hello,
i try to print vase with bottom layer 2,3,5, and 7 and on7 was look good ( with 0.15 ) but after 3 times put water inside it leek...
How to do without leek...also same situation with self watering planter...it leek...here i try with thicker layer but no help...
thanks in front...mini is printer and petg ...
Postato : 12/01/2023 9:11 pm
René
(@rene-3)
RE: help with vase
I think waterproof printing in vase mode is not possible.
At least if you only have one wall (perimeter) printed.
For a waterproof print you need more walls (perimeters).
With the search option of this forum I came across the following similar questions,
maybe you can find the answer there.
https://forum.prusa3d.com/forum/?wpfs=waterproof+printing
Postato : 13/01/2023 12:52 am
tom
 tom
(@tom-27)
RE: help with vase
i try what is on instruction site for vase....with one perimetar is ok ( no leak ) but floor is leaking with bottom layer 2,3 and last 7 is leak...
i will now try with 0.05 and see if that help...if not will look on link what send me...thanks
Postato : 13/01/2023 2:41 pm
