Help with slicer settings ?
Sfbrain
(@sfbrain)
Hi Guys,
Happy New Year
I have my Mini well dialed in now, with great prints coming off it.
I plan to print something where the designer of the model says 'print slowly' ?
As a newbie, i have no idea what settings i should be changing in Prusaslicer.
The attached photo is of the Prusaslicer settings page for 'speed', can someone advise as to what i should be changing
Thanks
S
Postato : 02/01/2020 4:01 pm
Gabriel S
(@gabriel-s)
RE: Help with slicer settings ?
The simplest way you could do this is to export the G-Code as-is from PrusaSlicer, and load it into the Mini. Then, immediately select the "Tweak" gear icon next to the pause icon, and change the print speed from 100% to, say, 50%. You have to do this each time you print that model, but then you don't have to worry about specific values and adjustments. Slowing the speed down is not as simple as just taking all those values in PrusaSlicer and dividing them by 2.
Postato : 02/01/2020 4:16 pm
1 persone hanno apprezzato
Sfbrain
(@sfbrain)
Posted by: @g-j-sieben
Thanks buddy
Will try that
S
Postato : 02/01/2020 4:27 pm
