Help. Supports not generating on inside bottom cutout.
Dschiri1
(@dschiri1)
I don't know how to solve this problem that I have had forever and I just need to find the correct solution.
Description a solid 100 mm x 100 mm 25mm high. Cutout a square 20 mm x 25mm 10mm high out on bottom center.
material: any
select supports: Everywhere
when slicing no supports for the cut out.
If I try to print, the print fails.
What I usually have to due is rotate the print off of z axis 1 degree and then it will generate the supports.  This introduces other problems ie print edges lifting
I have tried to use the paint on support feature while selecting "for support enforcers only" and still does not work.   What am I missing?  Is there a box that needs to be checked?  I have looked  beginners, advanced, and expert with no luck.
Thanks
Questa discussione è stata modificata 5 years fa da Dschiri1
Postato : 01/05/2021 6:18 pm
RE: Help. Supports not generating on inside bottom cutout.
There is a setting in Pslicer for supporting bridges; for internal bridges you want this setting unchecked.
Also - I am guessing here; you may want to ZIP and post your .3MF so we can see exactly what your are dealing with.
Questo post è stato modificato 5 years fa da --
Postato : 02/05/2021 2:41 am
