Good Outside External Perimeter. Horrible Inside External Perimeter
IAppearMissing
(@iappearmissing)
I can not figure this one, and it is an issue that has just developed recently in the last two prints. I am printing a two-compartment tray, and one compartment looks ok on the inside, the other awful.
The truly odd thing is the outside external perimeter looks fine.
I can not figure out what is going on here. I have tightened my belts, and I have raised the z offset a bit nothing helps. Please help.
Veröffentlicht : 04/08/2020 12:23 am
Benji
(@benji)
RE: Good Outside External Perimeter. Horrible Inside External Perimeter
Check your print speeds. There are different settings for those perimeters. However, the default should be perfect. I suspect it to be an issue with your hotend heatcreep and clogging. Is that print in PLA, and if so, does the same issue occur with PETG?
Diese r Beitrag wurde geändert Vor 6 years von Benji
Prusa Mini Silicone Bed Leveling Mod: https://bbbenji.github.io/PMSBLM/
Veröffentlicht : 04/08/2020 12:32 pm
IAppearMissing
(@iappearmissing)
@benji
Yes, I have not changed any of the defaults in PrusaSlicer for speed. Yes, it is PLA. I will have to try PETG and see if that makes a difference.
Veröffentlicht : 04/08/2020 3:47 pm
