Gaps between the start and end of layer (walls, 2 perimeters)
Kate
 Kate
(@kate)
Hello! I printed with a 0.6 nozzle and noticed, what there are gaps between the start and end of layers. I use Prusa Slicer with a preset for Prusa  Mini 0.6 nozzle. I can't understand, how to fix it. Something with a retraction?
Opublikowany : 15/05/2020 8:08 am
Matteo Cristini
(@matteo-cristini)
RE: Gaps between the start and end of layer (walls, 2 perimeters)
Hi! I'd like to help but honestly I don't know where to start here. Does it happen only with this particular model, or on every print? And how did it look in the slicer preview? Maybe try adjusting the layer seam setting... Looking forward to helping 🙂
Opublikowany : 18/05/2020 2:30 pm
Posted by: @miraghem
Try to lower the retraction value or set to 0. In order not to exceed the maximum feed volume, I would also reduce the printspeed.
Opublikowany : 18/05/2020 4:56 pm
Kate
 Kate
(@kate)
@matteo-cristini, @karl-herbert, thank you for your answers!
Today I started to print 4 pieces for one project. I want to try one by one setting on each piece. For the first one, I changed a volumetric speed from 15 to 11.5. Next will be a retraction setting.
Opublikowany : 19/05/2020 4:17 pm
