First time PETG - it's a mess!
c2
 c2
(@c2)
Hi all. To give you some context, I'm not an expert but with PLA I usually get the print I want.
I bought a spool of PETG from Prusa and this is my first time dealing with this kind of filament. It is driving me crazy. I was expecting that using the PETG defaults in PrusaSlicer to get, at worst, a barely acceptable print. But this isn't even remotely the case.
With the default speed, the plastic almost doesn't stick to the headbed at all, but I was able to get a somewhat decent first layer slowing down the first-layer head speed to 10 cm/s. It isn't as good as the first layer of a PLA print, but it is acceptable and maybe I will improve it later.
The real mess begins with the second layer. Please take a look:
What the hell is happening here? That stringy abominion should be solid infill, according to Prusa Slicer. You can also see problems with the skirt and the outer perimeter.
I slowed down the solid infill speed to 20 cm/s for non-first layers, print time by the way skyrocketed, and this is what I get; with the default speed it is even worse. If I let the print go, the mess continues for the next 3 to 4 layers and then normalizes, and the print continues decently till the end.
Could I have a faulty filament from a bad production batch? Any suggestions?
I'm using the satin powder-coated print sheet, at 85°C the first layer sticks well and letting the print cool to 50°C or lower it comes off nicely. So, I guess, the print sheet is not my problem here.
Thank you for your help.
Best Answer by FoxRun3D:
I don't have a Mini anymore but while I had my Minis I printed a lot of PETG using default settings. From the picture my gut feeling is that your live Z calibration is off. Try a calibration strip like this https://www.printables.com/prints/105404 to get a perfect first layer.
In all my years I've never seen this happen but sure it's possible. But my money is on bad Live Z.
This topic was modified před 10 months 2 times by c2
Napsal : 29/06/2025 9:28 am
RE: First time PETG - it's a mess!
Napsal : 29/06/2025 12:36 pm
1 lidem se líbí
c2
 c2
(@c2)
You were absolutely right!
I printed that calibration strip and landed a -1.78 Z offset. I never thought it might be different from the Z offset for PLA. With PLA I always used -1.33, but I'll check it again next time I'll print with it.
Now I'm printing with all default PETG values, everything is fine. I guess I learnt something today. Thanks a lot!
Napsal : 29/06/2025 2:25 pm
1 lidem se líbí
_KaszpiR_
(@_kaszpir_)
There shouldn't be a difference in the z offset between PLA or PETG ( or any other filament) and the same print sheet.
If you change the print sheet you need to readjust the z offset, because they will differ in height.
 You can store settings per sheet in the printer, AFIR you can have about 4 presets.
Another option could be a skewed print head, it is very easy in the Mini to twist the printer along the X axis, unfortunately.
Napsal : 29/06/2025 3:54 pm
c2
 c2
(@c2)
I definitely changed the print sheet moving from PLA to PETG, but I thought that the bed levelling pass before each print would have corrected for the thickness difference. Now I know that it doesn't.
I can't see any X axis twist, but I'll pay attention to it in the future.
Thank you.
Napsal : 29/06/2025 4:40 pm
A few thoughts:
That delta is exactly the -0.4 difference between a smooth and a satin sheet.
Mesh bed leveling can compensate for small differences but not the difference between a smooth and a satin sheet.
That's the way to go.
True, but PLA is also much more forgiving if the live z is only marginally correct; PETG leaves no prisoners. From the OP's post it wasn't clear upfront if it was a case of badly calibrated first layer or a change of sheets but the right solution in either case was to redo Live z.
Napsal : 29/06/2025 11:18 pm
blauzahn
(@blauzahn)
The PINDA detects the steel of the sheet, not the foil or powder based coating. Those differ in thickness by 0.4 mm.
Napsal : 30/06/2025 5:46 am
