Does anyone know what could be causing this globbing and stringing I am seeing?
XFour96
(@xfour96)
I have recently been seeing major globbing and stringing on my prusa mini with PLA, it did not use to do this.
I looked online for help as to why, and I have already done the following:
  • Cold pull the filament
  • Replaced the nozzle ( it had hundreds of hours of printing on it anyways )
  • Tried a new spool of filament
  • Reduced the temperature of the PLA while printing to 190C
  • Increased the retraction as I saw some videos showing that those settings helped
  • Slightly increased the move speed of the printer when not printing
After all that, a string test still results in what is seen in the attached image. Does anyone know what could be the issue?
EDIT: I have noticed that when the printer is heated up but idle, some filament is still extruding. I am assuming this may be a pressure issue? If so, does anyone know how to fix that?
This topic was modified 4 years ago by XFour96
Posted : 21/12/2021 6:36 am
Zoltan
(@zoltan)
Member Moderator
RE: Does anyone know what could be causing this globbing and stringing I am seeing?
This is a disease of a small and sharp objects I would advice to try jsut put on bed one more object of some shape ( cube?) same height as your model to give the chance to the nozzle to extrude some strings to this object. Or  just multiply the number of your objects.
Posted : 21/12/2021 8:11 am
Your filament is damp.  Look up threads on how to dry it.
Cherio,
Posted : 21/12/2021 9:54 am
@bobstro has some good notes on minimizing stringing: https://projects.ttlexceeded.com/3dprinting_techniques_calibrating_filament.html
Also, the oozing you're seeing idling at temperature is normal. Needle nosed pliers are your best friend to help with that.
Posted : 21/12/2021 11:59 am
