Collapsing Corners
I'm really not sure how to describe this issue the corners have started to collapse. It's only started doing this recently as the same print the other day with the same filament was fine. As I can't really describe the issue not sure how to find a solution any help is appreciated. I'm using Mini+ with Input Shaper .4 nozzle.
Opublikowany : 17/10/2023 8:23 am
RE: Collapsing Corners
Does it look fine with a non-IS profile?
Opublikowany : 17/10/2023 4:39 pm
