Clearly visible layer lines
Harakiri
(@harakiri)
Hi there,
besides the support, I‘ve used all the standard settings in prusa slicer with Prusament. Any idea what needs to be done here? Thanks a lot!
Veröffentlicht : 16/02/2021 7:42 am
Mitglied
RE: Clearly visible layer lines
Check your hotend, x, y, and Z axis for movement.  There might be some flex.  Also check your grub screws and belt tension.
I had similar rining and it was a loose y axis grub screw.
Veröffentlicht : 16/02/2021 11:00 am
Harakiri
(@harakiri)
Hi @cwbullet I've checked the belt tension according to https://help.prusa3d.com/en/article/adjusting-belt-tension-mini_157324 but how do I know how "strong" the tension needs to be? I can freely move the x and y axis. The Hotend is static and in place with all 3 grub screws.
Veröffentlicht : 16/02/2021 11:33 am
