RE: Clearly visible layer lines
Check your hotend, x, y, and Z axis for movement. There might be some flex. Also check your grub screws and belt tension.
I had similar rining and it was a loose y axis grub screw.
Respondido : 16/02/2021 11:00 am
Topic starter
answered:
Hi @cwbullet I've checked the belt tension according to https://help.prusa3d.com/en/article/adjusting-belt-tension-mini_157324 but how do I know how "strong" the tension needs to be? I can freely move the x and y axis. The Hotend is static and in place with all 3 grub screws.
Respondido : 16/02/2021 11:33 am
