Can the Mini print TPU ?
raymate
(@raymate)
As the title says, TPU is not listed in the spec for filament types the Mini can handle.
Any reason why it can't be printed with the mini, I've never used TPU before im strictly PLA at the moment but want to try TPU for a phone case im working on.
Thanks
Prusa Mini+ (Ordered Dec 19,2020 - Arrived Feb 21,2021) stated clicking Mar 2nd / MP Select Mini V2
Veröffentlicht : 19/12/2020 3:51 pm
Mitglied
RE: Can the Mini print TPU ?
Yes.  I can confirm it will.
Veröffentlicht : 19/12/2020 4:42 pm
raymate
(@raymate)
Posted by: @cwbullet
Thats good news, thanks
Veröffentlicht : 19/12/2020 4:49 pm
Royce_FPV
(@royce_fpv)
what settings?  noobie here, bought the mini to print TPU FPV drone parts... TPU is pretty much my primary need... as a noob and with no presets, I'm worried about digging through the gears to pick out filament.
Veröffentlicht : 18/11/2021 12:45 am
languer
(@languer)
Any pointers on how to best achieve success with TPU on the Mini ?
Veröffentlicht : 18/11/2021 6:39 am
Nickstats
(@nickstats)
I was honestly surprised when I threw some tpu at my mini, and it just printed it without any problems. My one piece of advise would be to print nice and slow. I usually run mine at around 50mm/s while printing 95A, but ymmv.
Veröffentlicht : 19/11/2021 2:49 am
Royce_FPV
(@royce_fpv)
Well I just went for it. Heat at 215.  20 (.20? Sorry) mm speed.  Tpu spool temp was 200 - 220. Lots of strings, but usable print.  95a TPU.
Veröffentlicht : 19/11/2021 3:27 am
Mcdriver
(@mcdriver)
what about Flexfill 98A? I haven't seen a profile for it.
Thank You
you don't know what you don't know, neither do I
Veröffentlicht : 22/11/2021 10:49 pm
Nickstats
(@nickstats)
There is a profile for Fillamentum Flexfill 98A in Prusa Slicer. I've used it with my 95A and it works just fine.
Posted by: @mcdriver
Thank You
Veröffentlicht : 22/11/2021 10:58 pm
Antimaterie
(@antimaterie)
I use sainsmat TPU and it worked great on my mini. It has a profile in prusaslicer. I set the temperature to 215C and changed retraction length to reduce stringing. Mostly I use the satin sheet or for models with larger base area the steel sheet. In fact it prints more easily then regular (prusament) PLA. Never had adheasion or extrusion problems. Stringing is a topic for complex parts, but it is manageable.
When I load the filament I choose "PLA" from the menu, because the sainsmart tpu didn't need high  temp.
see some of my tpu prints here (the "red" ones): https://www.prusaprinters.org/social/113164-antimaterie/prints
Veröffentlicht : 07/12/2021 9:17 pm
RandomInsano
(@randominsano)
Mitglied
For others who may need it spelled out like I do, use the "Configuration Assistant" under the "Configuration" menu to add new filaments. Jump to the "Filaments" section on the left-hand side, then the TPU filaments exist under the "FLEX" type. My brand wasn't there, but it's a lot closer than just guessing on speeds and feeds.
Veröffentlicht : 23/08/2024 4:04 pm
JBinFL
(@jbinfl)
Yes, and if you have a filament that is listed in the filament profiles, it is pretty much plug and play.  I printed some Fillamentum FlexFill 98A today for the first time.  The only thing i did was loosen the filament idler screw a couple of turns and sliced with the standard filament profile and pressed go and got multiple perfect prints in a row...  Amazing!
Strange women, laying in ponds, distributing swords, is hardly a basis for a system of governance!
Veröffentlicht : 26/09/2024 1:20 am
Xa_Vise
(@xa_vise)
Mitglied
Yes it does support it.
I used Polymaker Polyflex TPU95.
I went to their website, download the mk3 print profile and modified it for the mini. it work immediately. I used the satin bed plate. and the filament was keep at 13% humidity.
https://polymaker.com/download-material/
Veröffentlicht : 10/11/2024 1:08 pm
mark
 mark
(@mark)
Posted by: @xa_vise
The Mini is a way different printer than the MK3. Because of the Bowden tube it oozes more and needs to print slower, especially with soft stuff. I started with the Prusa Slicer TPU profiles and have good results, but others pretty much universally like the Bondtech extruder to improve printing of soft stuff like TPU, especially for the softer TPUs.
Regards,
Mark
Veröffentlicht : 10/11/2024 6:44 pm
MS
 MS
(@ms)
Can you help with Polyflex TPU95 settings for the Mini?
Veröffentlicht : 12/03/2025 1:01 pm
MS
 MS
(@ms)
Posted by: @xa_vise
Veröffentlicht : 12/03/2025 1:44 pm
