Callapsing Master Sword with Replaceable Blades problem
Here is the model I'm having trouble printing: https://thangs.com/designer/3dprintingworld/3d-model/Collapsing%20Master%20Sword%20with%20Replaceable%20Blade-35659
I have a Prusa Mini+ and I scaled the hilt and pommel down to 70%, 0.15mm quality with 15% infill. The hilt printed wonderfully and so did the pommel with a brim with no supports. However, when screwing on the pommel to the hilt, they don't line up. They are a little over 90 degrees off when fully screwed on. I can't figure out how to change the settings to get them to screw together correctly.
I have tried printing the threads on the pommel at 0.20, pushing the pommel into the floor so that less of the pommel is printed, but I still can't seem to line it up. Any suggestions?
RE: Callapsing Master Sword with Replaceable Blades problem
This is unlikely to get answered in the Prusa XL forum. You might try the Prusa Mini forum.
I have switched it to the right forum. Sorry and thanks.
