ABS with raft awful bottom of object
El_Draque
(@el_draque)
I am printing with eSun ABS on the smooth sheet with glue stick and I am printing with Raft (3 layers) + Brim (8 lines) to try to prevent warping which sometimes its still warping...but anyways when the print is finished and i pry the raft off I am left with a very awful looking bottom of the print, how can I prevent this?
Veröffentlicht : 20/08/2021 3:49 pm
Mitglied
Raft
I am not sure why you are using a raft.  Can you post an image of what the print is supposed to look like?
I rarely use a raft.
Veröffentlicht : 20/08/2021 4:10 pm
El_Draque
(@el_draque)
Re: cwbullet
its just flat bottomed. I am trying with raft to attempt to prevent edge warping which i have been having in almost every print. I am printing in a small closet so drafting isnt an issue
Veröffentlicht : 20/08/2021 5:11 pm
mark
 mark
(@mark)
Use a Draft Shield
I haven't used ABS, but have used ASA. A draft shield works well for me, spaced away from the object but as tall. It keeps the heat in better. I just clean the bed, never using a glue stick. Prusa does not recommend a glue stick for ABS either. Aren't the fumes bad? I have a vented enclosure with outside exhaust for printing ASA, just enough air flow to not get fumes in the room. I've never had problems with bed adhesion. Overhangs don't do well though.
Regards,
Mark
Veröffentlicht : 21/08/2021 4:55 am
towlerg
(@towlerg)
Is a raft suitable to prevent warping?
I'm pretty sure a raft would make warping worst. Try a nice big brim, mouse ears and a draft shield. Ultimately an enclosure.
Veröffentlicht : 21/08/2021 9:06 am
Mitglied
RE: Raft
Posted by: @towlerg
That is my experience.
Veröffentlicht : 21/08/2021 7:17 pm
