Z Height at limit -2.000 but nozzle does not reach textured metal sheet surface because it is too thin?
I am facing an issue which prevents me from printing on my powder-coated sheet because I would need a Z height correction of bigger than -2.000 but thesis the maximum value that can be used. Using my PEI sheet which has a thickness of 1.2 mm requires a Z Height correction of around -1.680. My powder-coated sheet has only a thickness of 0.62 mm (so 50% thinner compared to my PEI sheet) which would require a z-height correction of -2.300 to make the filament stick. But Life Z adjust stops at -2.000.
I read in other articles the powder-coated sheet is some 0.2mm thinner than PEI, in my case it is 0.6mm thinner and, hence, does not work on my brand-new mini+. Nozzle doesn't reach the surface as needed ...!?
Anyone facing same kind of issues in the past? Appreciate any advice how to adjust the Z height to let me also use the textured metal sheet which isn't cheap to buy, actually.
Thanks, Markus
RE: Z Height at limit -2.000 but nozzle does not reach textured metal sheet surface because it is too thin?
I had that on one of my printers. Readjusting the Super Pinda Probe by moving it closer to the print bed fixed it.
@fuchsr
Thank you for ultrafast response. I already moved the SPINDA a bit down and figured no better result. Apparently, I need to bring it still closer to the bed. Will definitely try agin. Maybe I have overseen something.
=Markus
I follow the instructions in the knowledge base for spinda replacements but I use a 0.8mm feeler gauge instead of a zip tie to measure the distance.
You must go higher with the Sensor. Mini or Mini+?
@rainer-2
You’re probably right. Higher, lower, I don’t really know, I just use my feeler gauge to find the right distance.
The new Sensor from the Mini+ must be higher then the old one.
Maybe twice a Credircard.
Since the switching distance of the SPINDA is somewhat larger, you ideally take a 1.50mm thick feeler gauge or something similar. Then, after adjusting the firstlayer, the value should be between -1,000 and -1,500.
SPINDA (Mini)
@karl-herbert
Thank you all,
yes the SPINDA had to be adjusted higher to make the printhead move "lower". It was clear for me what you meant. And I re-adjusted my SPINDA again and, yes, now I can mesh-level the bed using my textured metal sheet. Switching back to the PEI requires to adjust the Z-Height correction accordingly which is pretty fine now. So, issue solved.
You can go to the 4.3 RC1 Firmware with Sheet Profil. 😉
@rainer-2
Can't wait to download it, just for that one feature!
