Z axis noises and vibration only when going down
I have these noises that has gradually gone worse over time. At start it was only 2 points, but now, suddenly, it's all the way. It is only on the way down.
I have tried loosening the lead screw under the z axis motor and retightening several times. I have printed a z rod cleaner tool to be used with paper towels and used it several times, to no avail.
The printer is from November and hasn't printed much. I am unsure what my next move should be and am asking you for guidance.
The printer prints fine apart from the noises.
Thanks for your time
Respondido : 27/03/2026 9:40 am
RE: Z axis noises and vibration only when going down
See https://forum.prusa3d.com/forum/postid/209006/
Respondido : 27/03/2026 5:52 pm
