Z axis banding
luislafuentemedina
(@luislafuentemedina)
Z axis banding
Why is this banding happening? Possible causes? Suggestions?
Postato : 05/10/2021 7:20 am
Utenti
Subtle
What are you printing?
Z Banding is often created by wobbling or movement in the axis as the Z raises:
https://makershop.co/z-banding-z-wobbling/
https://www.nikkoindustries.com/blogs/news/how-to-fix-z-banding
https://3dprinterly.com/how-to-fix-z-banding-ribbing-in-3d-printing/
This is very subtle and might not be Z Banding.  Can you show another angle.
Postato : 05/10/2021 10:21 am
luislafuentemedina
More details
It increases in the top layers.
It is more evident on the left side.
Postato : 05/10/2021 10:26 am
BogdanH
(@bogdanh)
It seems banding appears in equal intervals... what's inside the cylinder? Can you show us 3mf file of this object?
PS: Use "Save project" in PrusaSlicer to get 3mf file. To be able to upload in this forum, zip it first.
[Mini+] [MK3S+BEAR]
Postato : 05/10/2021 10:27 am
luislafuentemedina
More data...
Nothing inside the cylinder.
Unfortunately I can not share the data.
It was just printing fine and then this lines appeared.
I always use the same filament. It happend using the same coil. I use standard PLA printing parameters.
Postato : 05/10/2021 10:44 am
Utenti
RE: banding
I can’t really telll from the photos.  Understrusion and banding will do this but banding is usually more pronounced.
Postato : 05/10/2021 3:21 pm
luislafuentemedina
Banding
I just tighted some screws on the X axis and untight and re-tight the Z Axis.
I also increase my next print by 5 degrees.
I just remember that this problem appeared 2 days ago when the temperatures started dropping below 5 Celsius in the night, (I always print with an open window)... Could this be related?
Postato : 05/10/2021 3:28 pm
Utenti
Possible
It is possible.  Stranger things have happended.  I would look for play in you axis also.
Postato : 05/10/2021 3:36 pm
