Y-Axis test fails. Bearings hitting ends, but still wanna continue
You can see in the video that the bearings hit the bend end, but not smoothly. Seems like it wants to continue a few milimiters, but it bounces off at the end and the test fails.
- Checked the belt tension, seems fine. Followed Prusa guide.
- Re-reposition the left bearings, but still the same.
- Tried and older firmware and the same. Running 6.0.2 now.
RE: Y-Axis test fails. Bearings hitting ends, but still wanna continue
This is the Y-Axis test:
SELFTEST START Y-Axis Started fwd Y-Axis @50 mm/s 1064 -300 0 1114 -300 0 1169 -299 216 1229 -89 374 1289 210 362 1349 509 386 1409 808 382 1469 1107 352 1529 1406 386 1589 1706 372 1650 2009 350 1711 2313 384 1771 2613 408 1832 2917 370 1892 3216 360 1953 3520 384 2013 3820 408 2073 4119 358 2133 4418 392 2193 4717 408 2253 5016 348 2313 5315 390 2373 5615 414 2433 5913 356 2493 6213 380 2553 6512 404 2613 6811 376 2676 7125 354 2736 7424 388 2796 7723 404 2856 8022 354 2916 8321 388 2976 8621 412 3036 8920 352 3096 9219 386 3157 9523 410 3218 9828 380 3279 10132 360 3339 10431 384 3399 10730 372 3459 11029 360 3519 11328 384 3579 11627 370 3639 11926 350 3699 12225 384 3759 12525 416 3819 12824 358 3879 13123 390 3939 13422 416 4000 13726 376 4060 14025 356 4120 14324 404 4180 14623 376 4240 14923 346 4300 15222 412 4360 15521 374 4420 15820 344 4481 16124 388 4541 16423 374 4601 16723 344 4662 17027 386 4722 17326 410 4786 17645 412 4846 17944 342 4902 18212 0 length = 185.119995 mm rew Y-Axis @50 mm/s 4984 18212 0 5034 18212 0 5088 18212 258 5138 18074 382 5195 17789 410 5255 17490 390 5315 17191 352 5375 16892 376 5435 16593 390 5495 16294 350 5555 15994 376 5615 15695 388 5675 15396 350 5735 15097 384 5795 14798 386 5855 14498 348 5915 14199 382 5975 13900 386 6035 13601 348 6095 13302 382 6155 13003 414 6215 12703 356 6275 12404 380 6336 12101 414 6397 11796 384 6457 11497 354 6518 11193 378 6578 10894 382 6640 10585 392 6704 10266 384 6764 9966 378 6824 9667 402 6884 9368 382 6945 9064 352 7006 8760 378 7066 8461 390 7126 8162 360 7187 7858 384 7248 7553 410 7308 7254 388 7368 6955 360 7428 6656 416 7488 6356 388 7548 6058 358 7608 5758 416 7668 5459 386 7728 5160 356 7788 4861 406 7848 4562 384 7908 4263 356 7968 3963 380 8028 3664 376 8088 3365 346 8148 3066 370 8209 2762 412 8269 2463 344 8329 2164 378 8389 1865 402 8449 1566 352 8509 1266 376 8570 962 410 8630 663 380 8690 364 352 8750 65 408 length = 183.050003 mm fwd Y-Axis @62 mm/s 8868 -93 0 8918 -93 0 8972 -92 260 9165 994 386 9225 1369 354 9286 1750 354 9346 2125 380 9407 2506 380 9467 2881 380 9527 3255 406 9589 3643 406 9650 4024 406 9710 4399 376 9771 4780 376 9831 5154 376 9892 5536 376 9952 5911 356 10012 6286 382 10072 6661 382 10133 7042 382 10193 7417 406 10253 7791 376 10313 8166 376 10373 8541 356 10433 8916 356 10493 9290 382 10553 9665 382 10613 10040 396 10673 10415 378 10733 10790 376 10793 11165 356 10853 11540 356 10913 11914 382 10975 12301 382 11039 12702 358 11100 13083 358 11160 13457 358 11220 13832 382 11280 14207 408 11340 14582 408 11400 14957 378 11460 15331 378 11520 15706 358 11581 16087 358 11641 16462 382 11702 16843 382 11763 17225 382 11824 17605 382 11885 17987 384 11946 18367 398 length = 185.129990 mm rew Y-Axis @62 mm/s 12042 18420 0 12092 18420 0 12146 18419 256 12196 18249 366 12246 17937 390 12300 17600 410 12360 17225 390 12420 16850 378 12481 16469 390 12541 16094 358 12601 15719 348 12661 15345 374 12722 14963 374 12786 14563 348 12847 14182 358 12909 13795 348 12970 13414 348 13030 13039 374 13091 12658 374 13151 12284 410 13212 11902 410 13273 11521 400 13333 11146 390 13393 10771 390 13453 10397 360 13513 10022 348 13573 9647 374 13633 9272 374 13693 8897 410 13753 8522 390 13813 8148 390 13873 7773 350 13933 7398 360 13993 7024 374 14053 6648 374 14113 6273 400 14173 5898 392 14234 5518 392 14294 5143 380 14354 4768 350 14414 4393 350 14474 4018 374 14534 3643 400 14594 3269 400 14654 2894 392 14714 2519 392 14774 2144 350 14838 1744 382 14898 1369 350 14958 995 350 15018 620 376 15079 238 376 length = 183.360001 mm fwd Y-Axis @75 mm/s 15175 84 0 15225 84 0 15279 85 206 15329 287 356 15379 660 380 15436 1087 412 15496 1536 420 15557 1992 404 15618 2448 398 15678 2896 408 15739 3353 378 15800 3809 372 15861 4266 398 15921 4714 392 15982 5170 402 16042 5619 396 16103 6075 420 16163 6524 416 16224 6980 400 16284 7429 396 16344 7877 404 16404 8326 398 16465 8783 394 16526 9239 364 16587 9695 374 16647 10143 368 16707 10592 364 16770 11063 418 16831 11520 412 16892 11976 398 16953 12432 406 17013 12880 400 17074 13337 372 17134 13786 366 17195 14242 376 17255 14690 370 17316 15147 394 17376 15595 390 17437 16052 386 17497 16500 410 17557 16949 418 17617 17398 414 17677 17846 408 17737 18295 416 17798 18751 426 17859 19208 342 length = 191.690002 mm Y-Axis Failed
Have you checked the screws holding the pulley to the motor shaft? Had a similar problem a while ago with the y-axis test failing, turned out the grub screws became a bit loose and the pulley was slipping on the motor shaft.
https://help.prusa3d.com/guide/2-yz-axis-assembly_196824#197642
Thanks! It was the belt tension. The Prusa support was really awesome and helped me with that.
