Y-Axis started sticking.
Just posting this in case it helps anyone else who has recently received their Mini.
I've had my Prusa Mini for about a month and a half now.
I had my first issue this morning after almost 6 weeks of constant use.
I'd tell you how many hours of print time I had, but I can't find it anywhere.
The Y-Axis started sticking. There was a squeaking sound and then a slight grinding sound.
After an auto-home failed, I turned the printer off, disconnected the power removed the magnetic bed, removed the heater bed, and then the 6 locking nuts from the Y-Axis carriage.
Once I had the bed removed I found that the single bearing on the right was grinding badly.
I applied lubrication, and rotated the bearing while sliding along that rail and after a few passes it smoothed out and all the grinding sounds went away. I applied a bit more lubricant to both rails and double-checked each bearing. With everything moving smoothly, I re-assembled the printer and it started printing again just fine.
All your filament are belong to us!
RE: Y-Axis started sticking.
I've had my MK3S since mid Feb and have been printing non stop. This past weekend I had a shifted layer and stopped the print. I re-ran the xzy calibration and the bed seems to stick. It's also real tight moving forward/back with the power off. Much tighter that my second MK3S. I bought them both assembled and slowly learning the hw troubleshooting side. Aside from the grinding sound, I'm having the same trouble. Going up to try lube now.
The lube fixed it. I wouldn't have thought that the bed would freeze up that badly but the lube fixed all my problems. Thank for your post.
