Y-Axis seems to be shorter than it should be
elenyio
(@elenyio)
When I move my Y-Axis manually towards 0, at about 12, it starts skipping, not able to move further. If I force it to 0 and then go back toward 180, I encounter the same issue.
Only thing is, this printer has worked fine before, and I didn't change anything about it physically at the time this issue first appeared. Firmware update and even factory reset have not helped.
Anybody got any ideas?
Postato : 07/03/2022 6:33 pm
RE: Y-Axis seems to be shorter than it should be
Have you lubricated the smooth rod and bearings?
Postato : 07/03/2022 10:20 pm
