Y axis lacks full range of motion and fails Y axis test.
Prusa Mini fails y self test.
Attempted solutions
- Adjust belt tension
- Clean rods & bearings
- Lube bearings & rods
Noticed when lubing the rods that the bed does not travel as far as other prusa minis. (See picture)
Please advise. Thank you.
Publié : 30/10/2024 1:53 pm
That grip on the bearing looks misplaced. I suggest checking y axis bed mount if is correct, any screws protruding too far and thus hitting the frame?
https://help.prusa3d.com/guide/how-to-replace-a-heatbed-mini-mini_156765 here is guide how to remove the heat bed so you can see the bed frame and then check the screws and any obstructions.
Look around Prusa help site for more.
Publié : 30/10/2024 6:55 pm
1 personnes ont aimé
