[Rozwiązany] Y Axis "Clicking"
StinkyPete
(@stinkypete)
Y Axis "Clicking"
My Prusa Mini has all updates applied, and is running a Bondtech Extruder and Heatbreak.  It's done a lot of work and print quality is excellent.    Over the last few days I've noticed  that as the bed moves back and forth on the "Y-Axis" there is a significant series of clicking noises.   I've disconnected the belt, and the clicking persists.   As I manually slide the bed back and forth,  I feel a very slight bind just before a click, so I suspect that it's in the bearings that run on the smooth rods.
Any suggestions would be welcome.
Opublikowany : 01/02/2024 4:20 am
Check the smooth rods are smooth - not scratched, no crud self-glued to them.  Then try lubrication and let us know if the problem persists.
Opublikowany : 01/02/2024 4:57 pm
StinkyPete
(@stinkypete)
RE: Y Axis "Clicking"
I've replaced the bearings on the "Y" axis and the porblem is resolved.
Opublikowany : 11/02/2024 9:03 pm
