Y Axis "Clicking"
My Prusa Mini has all updates applied, and is running a Bondtech Extruder and Heatbreak. It's done a lot of work and print quality is excellent. Over the last few days I've noticed that as the bed moves back and forth on the "Y-Axis" there is a significant series of clicking noises. I've disconnected the belt, and the clicking persists. As I manually slide the bed back and forth, I feel a very slight bind just before a click, so I suspect that it's in the bearings that run on the smooth rods.
Any suggestions would be welcome.
Check the smooth rods are smooth - not scratched, no crud self-glued to them. Then try lubrication and let us know if the problem persists.
RE: Y Axis "Clicking"
I've replaced the bearings on the "Y" axis and the porblem is resolved.
