y axis belt replacement
KTH
 KTH
(@kth)
i messed up n block my y axis during print n the belt came loose.
i havent went in to take a closer look to check the damage yet.
in the event that i need to change the belt, will it be possible to buy from my local hardware store? instead rtom prusa shop?
what's the belt specs?
Postato : 31/10/2021 8:06 pm
KTH
 KTH
(@kth)
is it the same as Creality?
Postato : 31/10/2021 8:11 pm
Urshurak776
(@urshurak776)
Belt info
Y-axis belt 496 mm
GT2 belt, 6mm wide, 496mm long.  Same as creality (except length is different.)  I had bought about 6 feet as replacements for my Ender 3.  Wound up using some on the clone mini I built as the ones that it came with were pretty much junk.  Recommend getting some gates replacements if you don't want to buy from PRUSA.
Postato : 01/11/2021 3:49 pm
federicopallitto@gmail.com
(@federicopallittogmail-com)
RE: y axis belt replacement
Hello, the same happened to me, i woke up and the belt now is loose. How can i adjust the belt?
Postato : 06/11/2021 1:07 pm
Dan Rogers
(@dan-rogers)
Service life on these belts is 50 years .... just saying
Postato : 06/11/2021 1:41 pm
KTH
 KTH
(@kth)
I manage to get my Y axis back up again, after multiple tries.
https://help.prusa3d.com/en/guide/2-yz-axis-assembly_196824
Try Step 30 Y-belt tensioning.
if fail, then loosen Step 17 Mounting the MINI-Y-belt-idler.
redo Step 28 Y-axis belt guidance,
then check Step 29 Aligning the Y-axis belt
tighten again for Step 30 Y-belt tensioning.
dont tighten too much
it took me a few tries to get it right.
good luck!
Questo post è stato modificato 5 years fa da KTH
Postato : 14/11/2021 7:40 am
KTH
 KTH
(@kth)
^above
Posted by: @federicopallittogmail-com
Postato : 14/11/2021 7:41 am
