Y-Axis Belt keeps slipping, getting loose
richsholm
(@richsholm)
Good day fellow Prusa enthusiasts!
I have a Prusa Mini that I have been happily printing on since March. Recently I've been having issues with the Y-axis belt. It just simply won't stay tight. I've gone and retightened it at the Y-axis belt holder under the build plate a few times now, but the belt slips on the teeth and gets loose again during a print.
Is it possible that I am putting it TOO tight in the holder? It will be loose and only have a grip on about 6 teeth of the belt which when printing circles like the benchy chimney/smokestack will make them ovals which is how I noticed the issue to begin with. I'll retighten it to be holding 8-9 teeth. I go to print a benchy to make sure my circles are not ovals and by the time it gets to the smokestack/chimney the belt has slipped and it is printing ovals again.
It seems that the issue shows up when printing at 100% speed, as when I print slower like 75%, it does not slip and the benchy turns out great as expected.
I am in the middle of printing a new Y-axis belt holder to see if that will fix things. I think my current part is F1 vs R1? I'd pull the part to verify but in the middle of a print haha.
Publié : 22/04/2020 4:47 pm
richsholm
(@richsholm)
RE: Y-Axis Belt keeps slipping, getting loose
Part was F2. Replaced with R1 and it definitely was tougher to get the belt in R1, so maybe that'll fix my issue.
Publié : 22/04/2020 5:52 pm
richsholm
(@richsholm)
Updated y-axis belt holder fixed my slipping belt issue.
Publié : 27/04/2020 3:28 pm
Winduser
(@winduser)
On my smartphone I can't find a link for the correct part. Someone could help me please?
Publié : 01/05/2020 8:18 pm
bobc
 bobc
(@bobc)
You can access R1 parts with this link https://github.com/prusa3d/Original-Prusa-MINI/tree/a626f94a1ef0431fb4d29430b2d2a43d7c684c29
Publié : 02/05/2020 11:36 am
Winduser a aimé
