Y axis belt has started squeaking
Tracy
(@tracy)
It's squeaking because it's rubbing against the left side of the pulley. Is it possible to realign the belt so it rides in the center of the pulley?
Best Answer by Oxygen:
I had the same and 'solved' it by pressing a piece of filament in
Napsal : 30/05/2020 6:18 pm
Oxygen
(@oxygen)
RE: Y axis belt has started squeaking
Stock MK4S with FW 6.2.6
Napsal : 31/05/2020 7:57 am
SS220
(@ss220)
Just wanted to add a "me too." I fixed it by jamming a folded up piece of 3X5 card stock in the same position that the filament pieces above were put.
Napsal : 03/06/2020 2:21 pm
1 lidem se líbí
Tracy
(@tracy)
@stevensmith
I jammed a tie wrap in there and ended up with a failed print after 5 hours due to a Y axis layer shift. Coincidence? I removed the tie wrap and I'm trying the print again. If it succeeds I'll try using a thick piece of paper instead.
Napsal : 03/06/2020 2:26 pm
