XY center differ between printer and Prusaslicer
X- and Y-axes does not have origins at center of the build plate. Both are approx. 3 mm off center.
I had some hope that this would auto-adjust when running the selftest, but it prevailed.
Is the correct procedure to adjust the bed shape origin in Prusaslicer?
(The printer is working like a charm apart from this. I found this when printing a 180 mm diameter circle. It seems to hit some software(?) end stop so about 1 mm of the print is lost.)
Best regards,
Lennart
Publié : 28/07/2022 9:01 pm
1 personnes ont aimé
