X Axis Stepper Motor
I need to replace my stepper motor. I started a print to find the X-axis wire pulled out when I returned. Any idea of the specs of this motor?
RE: X Axis Stepper Motor
It looks like a standard NEMA 17 - but with a bespoke cable.
Most come with socket in the stepper body so it's straightforward to modify the supplied cable for length.
The X axis doesn't do a great deal of work so, as long as you avoid the very cheapest. you should be OK.
Hth, Cheerio,
@diem
Thanks. I tried a could already. They won't work. I order a couple LDO 1.8 motors.
@cwbullet
I found this on their github;
Hope it helps.
Prusa Mini+ kit. BondTech extruder. FW 5.1.2
Prusa MK3S+ kit. Stock. FW 3.11.0
Prusa MK3S+, used. Stock. FW 3.13.3
@cwbullet
The Prusa LDO stepper motors are directly wired (no plug). I think this one should fit:
Which LDO-set did you order for the Mini?
42STH40-1004ASH
Thank you, I appreciate the help.
@cwbullet
Hope it helps.
That was essential. Thanks.
I tried a couple more stepper motors. I had an extra Creality X stepper. It would not spin. It did this off jumping as I tried to get to spin.
I also tried:
- https://www.amazon.com/gp/product/B07GDD2X4B/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1
- https://www.amazon.com/gp/product/B07GDBMT1D/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
- https://www.amazon.com/gp/product/B0817T5SRH/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
These all did the same thing. I wonder if the wiring is different for a Creality and Prusa Motor.
The only difference i can see that might be critical, is the rated current. 6.5v for the prusa/ldo and between 3.6 and 4.8 for those on amazon.
I might have missed something, or if they are speced differently to eachother.
@mrstoned
I wonder if there is any wiring difference.
@cwbullet
If you use other steppers, I would check if the connections match the pin assignment on the buddyboard (A, A-, B, B-). The colors of the wires will probably not match and you may have to change the cable positions.
NEMA 17 specifies only the motor mount. Electrical specifications differ wildly between NEMA17 motors. Voltage, Amperes and wiring must match, also steps/r can differ, 32, 64, 200 and 400 are all quite common. I didn't find electrical specs for Prusa Mini steppers.
UPDATE: cwbullet has already found the document with stepper specs. All similar steppers should work, but you might need to look your replacements documentation to get wiring to match the original.
@karl-herbert
Thanks. I will try that tonight.
@lupin
Makes sense.
@cwbullet
Have you found another source for the Prusa Mini motors?
Was going to try and give these a try and order the whole set as am having problems with the x axis.
Did you find a viable replacement?
These are the specifications of the Prusa Mini motors. A replacement motor should have similar specifications.
Maybe you will find something suitable here or here.
wbr,
Karl
Hi, I'm having difficulty sourcing the ldo model mentioned earlier, any other hint for x and y motor?
