X axis small shift in layers again
polo5959
(@polo5959)
Hello,
I have layer shifts on the x axis on my prints. I tried tightening the belt, realigning it, and put some grease but it doesn't work. What could be the issue? it use to work fine a few weeks ago so not sure what is going on... any suggestions?
Thanks
Veröffentlicht : 29/03/2025 2:26 am
_KaszpiR_
(@_kaszpir_)
RE: X axis small shift in layers again
Check the grub screws on the pulley on the X axis motor shaft if they are not loose, and tighten them.
Veröffentlicht : 29/03/2025 7:46 am
polo5959
(@polo5959)
That was exactly the problem! thanks
I have another problem tho wich I never managed to get around. when I print something with a hole like on this piece, I always have the layers lookinf slightly bigger, what can be the issue?
Diese r Beitrag wurde geändert Vor 11 months von polo5959
Veröffentlicht : 29/03/2025 11:42 pm
_KaszpiR_
(@_kaszpir_)
get used to it 🙂
or try structural profiles, or generally try slowing down the speed. It's a known issue.
Veröffentlicht : 30/03/2025 12:31 am
