Worlds first Teardown & BOM (Bill of Materials) & Closest look for Prusa Mini
pingu
(@pingu)
Well, due broken parts due shippment ( https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/unofficial-prusa-mini-wait-thread/paged/38/#post-179776 )
i had to take the new mini apart anyway. so i decided to do a full teardown of it. Feel free to share, but recognice my nickname and my work here please!
i will share this content chapterwise, as i have to work tomorow and need some sleep 😉
  • Base/Housing:
  • Budy Board to housing:
  • m3x8 : 4 pcs
  • m3n :4 pcs
Connection to upper Part:
  • m3x20: 7 pcs
  • m5x20r: 2 pcs
  • m3s: 8 pcs
Plate Thickness between extrusion and base: 5,35 mm
Extrusion lenght z axis: 289mm
Napsal : 17/12/2019 8:04 pm
2 lidem se líbí
pingu
(@pingu)
RE: Worlds first Teardown & BOM (Bill of Materials) & Closest look for Prusa Mini
Y axis (WTF about the "007" tag. eastereg, or codename for sneaky china production?
Belt Tensioner:
  • m3x20: 3pcs
  • m3nS: 2 pcs
  • m3nN: 1pcs
  • Flat Pulley, looks same as MK3 (no teeth)
Belt Lenght: 495 mm. GT-2
Extrusion: 262 mm 30x30 (2 pcs)
  • sliding nuts for extrusion: 3 pcs
  • m3x20r: 8 pcs
  • Rods: 279x8mm: 2 pcs
Stepper motor to base:
  • m3x12: 3 pcs
  • Display to base: m3nN: 1pcs
Bed to spacer:
  • m3x8: 9 pcs
  • Spacer lenght 6mm : 9pcs
  • screws bed to spacer: missed to measure
Bearings: LM8UU: 3 pcs
Bed Cable Cover:
  • m3x14 (1pcs)
  • m3nN
Napsal : 17/12/2019 8:18 pm
pingu
(@pingu)
Display: needs some further investigation. board ist clearly custom, but display reminds me to some old display on old phones, like the sony ericson slider series.
Display:
  • m3x8 : 4 pcs
Napsal : 17/12/2019 8:24 pm
pingu
(@pingu)
Details on the buddy board
Napsal : 17/12/2019 8:32 pm
1 lidem se líbí
Matthew
(@matthew-5)
007" Edition
It says 7 inch edition in a neat way with the quote symbol refering to the english symbol meaning "inch"
The thumb prints seem to refer to a thumb being the basis of the measurement.
Napsal : 19/12/2019 6:14 am
2 lidem se líbí
pingu
(@pingu)
Extruder to Cartridge:
  • m3x25 :3pcs
Extruder housing:
  • m3x25 : 3pcs
  • m3x14 :1 pcs + m3nN : 1pcs + 145 mm PTFE Tube
  • 1 bearing 625 z (not final clear. my bearing had a not good readable branding.. maybe someone else can verify)
  • m3x12 : 2pcs (to stepper motor)
  • Fitting kit für PTFE tube
Extruder Idler:
  • BEaring 525z+ pin (available on github as stl)
  • m3nS : 1pcs
  • m3x40 :1pc
  • spring (same as in  mk3s)
will be continued as i have time
This post was modified před 6 years by pingu
Napsal : 19/12/2019 9:00 am
Neolker
(@neolker)
It looks like older Buddy v0.1.4, on the GitHub was released Buddy v1.0.0.
The LCD uses quite common ST7789v driver according to Buddy firmware - nothing special.
Napsal : 26/12/2019 2:13 am
Bob
 Bob
(@bob-4)
Hey,
did you manage to take measurments for Z axis rods lenghts?
Thanks
Napsal : 06/02/2020 6:29 am
Texy
 Texy
(@texy)
Posted by: @robert-valencic
Hey,
Thanks
The Z rod is available as a spare part, and the description reads :
  • Diameter: 10 mm
  • Length: 341 mm
Texy
Napsal : 06/02/2020 11:09 am
Bob
 Bob
(@bob-4)
Thank you for info very much.
Napsal : 06/02/2020 11:11 am
Benji
(@benji)
Posted by: @pingu
Bed to spacer:
  • m3x8: 9 pcs
The screws (bed to spacer) are 3Mx3. They are also low profile countersunk Torx heads. If you were to replace them with 3Mx3 countersunk Hex, they will sit proud of the heatbed.
This post was modified před 6 years 2 times by Benji
Prusa Mini Silicone Bed Leveling Mod: https://bbbenji.github.io/PMSBLM/
Napsal : 25/02/2020 9:45 pm
Reggie
(@reggie-2)
you don't by chance have the break down of the top with the X axis and what screws go into the top stepper motor?
Napsal : 29/05/2020 4:10 pm
