Worlds first Teardown & BOM (Bill of Materials) & Closest look for Prusa Mini
Well, due broken parts due shippment ( https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/unofficial-prusa-mini-wait-thread/paged/38/#post-179776 )
i had to take the new mini apart anyway. so i decided to do a full teardown of it. Feel free to share, but recognice my nickname and my work here please!
i will share this content chapterwise, as i have to work tomorow and need some sleep 😉
- Base/Housing:
- Budy Board to housing:
- m3x8 : 4 pcs
- m3n :4 pcs
Connection to upper Part:
- m3x20: 7 pcs
- m5x20r: 2 pcs
- m3s: 8 pcs
Plate Thickness between extrusion and base: 5,35 mm
Extrusion lenght z axis: 289mm
RE: Worlds first Teardown & BOM (Bill of Materials) & Closest look for Prusa Mini
Y axis (WTF about the "007" tag. eastereg, or codename for sneaky china production?
Belt Tensioner:
- m3x20: 3pcs
- m3nS: 2 pcs
- m3nN: 1pcs
- Flat Pulley, looks same as MK3 (no teeth)
Belt Lenght: 495 mm. GT-2
Extrusion: 262 mm 30x30 (2 pcs)
- sliding nuts for extrusion: 3 pcs
- m3x20r: 8 pcs
- Rods: 279x8mm: 2 pcs
Stepper motor to base:
- m3x12: 3 pcs
- Display to base: m3nN: 1pcs
Bed to spacer:
- m3x8: 9 pcs
- Spacer lenght 6mm : 9pcs
- screws bed to spacer: missed to measure
Bearings: LM8UU: 3 pcs
Bed Cable Cover:
- m3x14 (1pcs)
- m3nN
Display: needs some further investigation. board ist clearly custom, but display reminds me to some old display on old phones, like the sony ericson slider series.
Display:
007" Edition
It says 7 inch edition in a neat way with the quote symbol refering to the english symbol meaning "inch"
The thumb prints seem to refer to a thumb being the basis of the measurement.
Extruder to Cartridge:
- m3x25 :3pcs
Extruder housing:
- m3x25 : 3pcs
- m3x14 :1 pcs + m3nN : 1pcs + 145 mm PTFE Tube
- 1 bearing 625 z (not final clear. my bearing had a not good readable branding.. maybe someone else can verify)
- m3x12 : 2pcs (to stepper motor)
- Fitting kit für PTFE tube
Extruder Idler:
- BEaring 525z+ pin (available on github as stl)
- m3nS : 1pcs
- m3x40 :1pc
- spring (same as in mk3s)
will be continued as i have time
It looks like older Buddy v0.1.4, on the GitHub was released Buddy v1.0.0.
The LCD uses quite common ST7789v driver according to Buddy firmware - nothing special.
Hey,
did you manage to take measurments for Z axis rods lenghts?
Thanks
Hey,
Thanks
The Z rod is available as a spare part, and the description reads :
- Diameter: 10 mm
- Length: 341 mm
Texy
Thank you for info very much.
Bed to spacer:
- m3x8: 9 pcs
The screws (bed to spacer) are 3Mx3. They are also low profile countersunk Torx heads. If you were to replace them with 3Mx3 countersunk Hex, they will sit proud of the heatbed.
Prusa Mini Silicone Bed Leveling Mod: https://bbbenji.github.io/PMSBLM/
you don't by chance have the break down of the top with the X axis and what screws go into the top stepper motor?
