Weird behaviour mid-print, then stops printing
Marcel
(@marcel-3)
Hi all,
I'm having some problems with my Purse Mini today. I got my mini about two months ago, no real problems. Today, it started behaving weird with two different prints I did, (two different models). Between these two, I've printed another model, which went great.. Let me describe the behaviour:
  1. The printing starts just fine, but after about 2 layers the head suddenly goes to it's extreme x-position, then back, then goes up in the z-directing.
  2. After that it starts squirting a load of PLA, again some weird x-axis behaviour, it goes back to it's original position (the last one where it printed properly)
  3. Then it kinda resumes printing, without depositing material, only to stop after one round. After that it just stops doing anything. I've the last bit of it on tape, I'll add it to this topic.
Last couple of seconds of the faulty print
The Lcd doesn't show any error, and there's nothing weird to see in the messages page. I've generated the gcode from an STL with PrusaSlicer, I've added the gcode, and 3mf file to the topic. I downloaded the STL from PrusaPrinters, from a pretty popular model (so I'm sure it's not in the model itself). As I said before, it also happened with a completely different model.
I also made a crash dump after it failed, no idea if it's any worth.
I hope someone has an idea what the cause of this is, I'm kinda clueless.
Thanks, Marcel
Respondido : 20/03/2022 6:47 pm
RE: Weird behaviour mid-print, then stops printing
That's indeed curious. I'm tempted to think there's something going on with the gcode but the 3mf and gcode files weren't attached to the post. You've got to zip the 3mf file or the forum software won't accept it.
Respondido : 20/03/2022 10:44 pm
Marcel
(@marcel-3)
Thanks for your reply fuchsr.
I've uploaded the crash dump and gcode+3mf zip, see them below.
dump.bin
gcode and 3mf files
Respondido : 21/03/2022 7:13 am
Marcel
(@marcel-3)
I noticed the video in the opening post isn't showing up, so posting it again:
https://forum.prusa3d.com/wp-content/uploads/2022/03/PXL_20220320_1731590772.mp4
Edited by Joan Tabbs, Moderator
Esta publicación ha sido modificada el hace 3 years 2 veces por Marcel
Respondido : 23/03/2022 4:00 pm
Zoltan
(@zoltan)
Miembro Moderator
Does it behave with the same Gcode file the same way in other prints as well?
Can you pls share FW version?
Respondido : 19/04/2022 12:23 pm
jcadcell
(@jcadcell)
I have 9 MINI printers and have had those symptoms several times now. I'm pretty sure the problem I'm having is with the flash thumb drives supplied with the printer. Try using a different USB stick.
Also, try saving a second copy of the gcode on your computer, then compare what is on the USB stick after you see this problem. I found the gcode was Ok on the thumb drive before inserting into the printer, then afterwards it had changed.
Respondido : 28/04/2022 1:12 am
