Watchdog Reset Error
I’m starting to get “Watchdog reset’ errors running 4.3.4 firmware and Prusaslicer 2.4.2 (IIRC).
I see some people having issues a couple or years ago, but not recently. It has happened at least twice- I remember longer prints more.
It might be a stick issue. I just got rid of a couple of older USB sticks due to read/write issue. The new ones are 16GB micro center cheap ones.
It might have been when it was in part of a print where it goes back and forth over a 15mm section. So maybe it jiggled the stick and caused the error.
I also am using a MBP computer with only USB-C, so I have an apple adaptor cable to standard USB. I almost wonder if part of the issue is the writing to the sticks?
I’ll go get some better USB sticks ?
Publié : 22/07/2022 7:04 pm
