Walls are not straight
I'm struggling to print 'correct' items on my Prusa mini+. The first and last layer are correct but the layers in between are off. The outsight walls are leaning to the insight and the insight walls are leaning to the outsight? Every print has to same problem, so it's not a coincidence.
I'm using the standard print settings from Prusa for PETG --> layer hight 0.2mm/infill Gyroid.
Filament (=prusament galaxy black) is brand new.
Someone had similar issue's are has an idea what can be the cause? Some pictures to clarify the above.
Many thanks in advance!
Napsal : 22/07/2021 5:29 am
Topic starter
answered:
RE: walls are not straight
Did some more test and my heated temperature was to high --> 100°C (I increased it fore a good adhesion). It seems to be to high...:-)
Napsal : 22/07/2021 7:56 pm
