USB Jack is broken
Thukill
(@thukill)
USB Jack is broken
Somehow, I mangled the USB Jack on the Prusa Mini, soldered to the Buddy board.  I am trying to track down a replacment jack that I can solder in place.  The pin-out on the existing jack is on the side of the jack and in a 4 -pin square formation. Most of the jacks I can find are 4 pins in a straight line.
Any thoughts on where I can find a part number for this jack or the jack itself?
Posted : 06/12/2022 7:01 pm
Distinctly Average
(@distinctly-average)
Thukill
(@thukill)
Wow, that is the jack and yes, there are 4 pins to the rear of the assembly but its not clear that they are part of it.  I didn't want to remove it till I get a replacement so I can see what I am dealing with.  At those prices, I could just buy the clone module and steal the jack or even give the clone a try.
Thank you!
Posted : 06/12/2022 9:08 pm
Distinctly Average
RE: USB Jack is broken
No worries.
I did search the usual sites like digikey, farnell, rs and mouser to no avail
JLC PCB have a few options but you would need to clip off the third mounting lug in the middle.
https://jlcpcb.com/partdetail/40400-906162A1011D10200/C39417
They have a few different versions of this in different colours such as
https://jlcpcb.com/partdetail/2892458-906562A1118D10200/C2763246
They may have an exact match but their search is all but useless and there are 241 pages to go through.
Posted : 06/12/2022 10:48 pm
Thukill
(@thukill)
Got excellent response by PRUSA support staff, including this link.  Enjoy
https://htmlpreview.github.io/?https://github.com/prusa3d/Buddy-board-MINI-PCB/blob/master/rev.1.0.0/ibom.html
Posted : 22/12/2022 4:46 pm
Distinctly Average
Prusa will never fall foul of right to repair laws should they arrive. Such a breath of fresh air.
I got into electronics at a very young age in the 80s. Things then were almost always well documented. It was often easier to get service manuals back then than it is now with the internet. Components were easy to come by and not restricted. How things have changed.
Posted : 22/12/2022 6:36 pm
