USB file pc write issue ? lan write ok - PrusaSlicer-2.5.2 Mini+ 4.4.1
RB
 RB
(@rb-3)
Mitglied
I can have usb memory plugged into the side of the mini+ I am also connected to the mini+ by lan
usb memory plugged into windows 10:  If I upload files direct from the prusaslicer to the usb - then place the usb in the mini+ the files do not appear.
usb memory plugged into mini+ If I upload the files direct from the prusaslicer to the mini+ via lan it puts the files in the usb and they then appear.
if I compare the two files on the usb they exactly the same - any ideas what is causing this issue.
I have already tried various usbs, various formatting approaches, refirmwared the mini and reinstalled prusaslicer
Veröffentlicht : 01/05/2023 9:42 am
_KaszpiR_
(@_kaszpir_)
RE: USB file pc write issue ? lan write ok - PrusaSlicer-2.5.2 Mini+ 4.4.1
Sounds like too quick pendrive removal after file copy?
After you copy files to USB, then look into the tray icons - there is 'Safely Remove hardware and Eject Media', select pendrive and press 'Eject <device name>',
Also in File Explorer right click on the pendrive letter, select Properties, Tools tab, Check.
Veröffentlicht : 01/05/2023 6:51 pm
