USB Drive with files is detected as empty
giuseppe
(@giuseppe)
Hello,
today my Mini+ is not be able to read files to print inside the usb stick. This one is perfectly read/write by computer but not by printer.
I've tried with another USB stick as well and the issue is still there. The printer detect the stick plugged but without any files inside.
Any help?
Thank you
FW: 4.4.1 (16-01-2023)
PS: Below some picture.
Publié : 18/07/2023 6:57 am
Tysonsw
(@tysonsw)
RE: USB Drive with files is detected as empty
Is this the original USB-drive or a new one? How big is it?
Printer: Original Prusa Mini+
Nozzles: E3D 0.25, E3D Nozzle X 0.4 , E3D 0.4, Bondtech 0.6 CHL
Printables: Tysonsw
Mastodon: [email protected]
Publié : 18/07/2023 7:16 am
giuseppe
(@giuseppe)
Both! Original and another one. The original is 8GB (FAT32) and the other one is 4GB (FAT32)
Publié : 18/07/2023 7:19 am
Hello
(@hello)
Probably live chat with prusa for replacement parts as it'd could be the usb port
Publié : 18/07/2023 9:33 am
mediafp
(@mediafp)
I have the exact same problem. I have two minis and one of the USB sticks that came with the machine is no longer readable by either one of the Minis. Both my Mac and PC can read it and sees all the files on it. It is formatted in FAT32 and I've even reformatted it in FAT32 and put all the files back onto it. But it still just says "Home" when I click on Print. Both Minis can read the other original USB stick so I know it isn't a problem with the USB drive itself.
How can this other un-useable USB stick be reformatted so the MINIs will see it again?
Ce message a été modifié il y a 3 years par mediafp
Publié : 25/09/2023 5:00 pm
gkas
 gkas
(@gkas)
Simple answer..... it probably can't be formatted. It's dead. Less than $10 for a new one.
Publié : 25/09/2023 7:30 pm
detezmorena
(@detezmorena)
Membre
So, reviving this topic and adding "my solution" (take it with a grain of salt) in MY case, the Prusa supplied USB Drive worked perfectly until I decided to grab it to use for another purpose quickly (installing Windows on a PC), so MY issue was that the USB Drive was not recognized by my MK4, I was able to identify and solve the problem by changing the partition table on the USB Drive from GUID to MBR.
As stated on this article https://help.prusa3d.com/article/sd-cards-and-usb-drives_112291
"If the USB stick will not work even after this procedure, it is either broken or its "partitioning scheme" is set as GPT, which is incorrect. It must be set as MBR (Master Boot Record). For how to change this, please see Microsoft's official documentation."
After a quick google search for "how to format usb as mbr" I was able to solve my problem and the USB Drive is now recognized again.
Edit: this solution was posted here as well by @nelisw https://forum.prusa3d.com/forum/postid/738794/
Publié : 17/11/2025 5:14 pm
