this is a USB-A-vertical-MX-67329-8000 https://htmlpreview.github.io/?https://github.com/prusa3d/Buddy-board-MINI-PCB/blob/master/rev.1.0.0/ibom.html (Molex 67329-8000)
USB cable spec is on page 10 https://github.com/prusa3d/Buddy-board-MINI-PCB/blob/master/rev.1.0.0/BUDDY_v1.0.0.pdf
there are 4 smaller pads:
1. +5V
2. Digital -
3. Digital +
4. ID - identification (can be be ground)
5. GND (the big four legs on top, you have red-white cable connected to it)
I always totally mix up the order of the pins so get a multimeter and check where +5V is and the rest of the pins should be straight forward.
so one of: black (left) or green-white should be 5V.
Napsal : 23/02/2026 10:42 pm
1 lidem se líbí
