[Rozwiązany] Upgrading the bearings on a Mini+
Sievers05
(@sievers05)
Since I have to partially disassemble my Mini + to address a Y-axis failure, I've decided to upgrade the bearings.  Looking through some older post on other forums, I saw people were using the Misumi LMU8 bearings. Has anyone done a bearing upgrade on their Mini? Did you use stock parts or an upgrade?
Thanks for the help.
Opublikowany : 04/08/2023 4:51 pm
Hello
(@hello)
RE: Upgrading the bearings on a Mini+
Use misumi bearings the should straight replace the other ones
Opublikowany : 04/08/2023 7:52 pm
Sievers05 polubić
Sievers05
(@sievers05)
After re-greasing the bearings, installing a new Z rail support bracket, making sure everything is square, my mini+ has now passed calibration.
I have successfully printed a raptor claw for my daughter.
Thanks for the advice.
Opublikowany : 06/08/2023 4:30 pm
