[Solved] Unload Filament Extruder Jam
Tallman
(@tallman)
I fixed the problem I had with my Mini+ filament unload where the motor would run for about 2 seconds then the gears jam.  This happened even if no filament was loaded.  The solution was to raise the height of the extruder pinion slightly.  The instructions say to use the 1.5 mm Allen key to set the gap, which I did originally.  Instead of using the flat sides of the Allen key I used the Allen key points which makes the gap more like 1.6 mm.  That fixed the problem.
Posted : 22/11/2021 5:12 pm
