Uneven temperatures across heatbed
Alabuk
(@alabuk)
First off, I bought my printer used, so I don't know all of it's history.
I downloaded one of the Z-offset calibration patterns from Printables.  I am printing with PETG on a satin sheet.  I had a lot of trouble with the PETG not sticking in front third of the heatbed.  I used a laser thermometer to measure the temperature at various points on the heatbed, and the front third of the hotbed is 10-15C cooler than the rest of the bed.  Any idea why this might be happening?  Or is it just time to replace the heatbed?
This topic was modified 2 years ago by Alabuk
Posted : 30/08/2024 10:07 pm
_KaszpiR_
(@_kaszpir_)
RE: Uneven temperatures across heatbed
can you provide temperatures with the bed sheet on it?
Either way maybe bed quality wasn't the best so maybe it's worth to replace.
Posted : 31/08/2024 7:29 am
Variation like that can be caused by as litle as a light draft...
but we can't really judge the first layer until you get the print sheet properly clean - look up threads here about cleaning.
Then protect from drafts, allow time for the print sheet temperature to stabilise and try again.
Come back if problems persist.
Posted : 31/08/2024 10:45 am
Alabuk
(@alabuk)
Here’s more of the steps I’ve taken debugging this issue:
I have cleaned my sheet with dish soap and water, followed by 99% IPA with no improvement
I’ve dedicated one side of this sheet to PETG and the other to PLA.   I get similar results with PLA on the PLA side of the sheet.
I print in an acrylic enclosure, and I get the same issue with the door open and closed.
Posted : 03/09/2024 12:38 am
_KaszpiR_
(@_kaszpir_)
Replace the bed or learn to limit used area when printing.
Posted : 03/09/2024 6:11 am
Your pictures clearly show poor adhesion even where the first layer looks OK  - if regular cleaning isn't working then maybe it's time for a drastic clean...
Work neat dishwashing detergent (Dawn/Fairy) into the surface of the sheet - wait for ten minutes then rinse it away with very *HOT* water.  Dry by dabbing with a fresh paper towel, handle by the edges only and finish drying by placing it on the heatbed and raising the temperature.
Adjust your first layer Z offset so the centre of the pattern is best and show us the result.
Posted : 03/09/2024 6:45 am
