Under extrusion....
OhLordy / Team Sausage
(@ohlordy-team-sausage)
Under extrusion....
Hello all
Please can someone advise whats going on here?
Stock MINI with a silicone sock printing Spectrum PLA at 215 (or 205)
I am waiting for my Bondtech Heatbreak and I recently loosened my heatsink and got the PTFE TIGHT at the top to try maintain pressure for this problem).
Now, this PLA has been printing beautifully some days and horrid some others and I use this on all my machines, so its NOT the white and its NOT the filament (its dry).
Posted : 09/11/2020 11:50 am
RE: Under extrusion....
Posted by: @justis224
Hello all
Hello and welcome to the Prusaforum!
Have you ever looked at the extruder?
Maybe the drive pinions are clogged or the idler screw is set too low.
It is advisable to perform a "cold pull" from time to time and check the smooth running of the filament in the PTFE tube.
Have you ever looked at the extruder? Maybe the drive pinions are clogged or the idler screw is set too low.
Posted : 09/11/2020 12:29 pm
@karl-herbert
Ill check those out. Dont think I have 50 hours on the printer yet though... thanks for the reply!
Posted : 09/11/2020 12:35 pm
@justis224
sorry, the link above does not work, now here:
https://help.prusa3d.com/en/article/clogged-nozzle-hotend-mini_112011
Posted : 09/11/2020 1:24 pm
