Too cold to start?
Stránka 2 / 2
pmu
 pmu
(@pmu)
What is the current mintemp on Mini fw 4.4.0 ?
Coud not figure out what happened to bug #688.
@karl-herbert any way to check this in the Prusa Mini firmware?
This post was modified před 3 years by pmu
Napsal : 30/01/2023 4:40 pm
RE: Too cold to start?
bed mintemp is 10 (max. 100) degrees C.
extrude mintemp is 170 (max. 290) degrees C.
ambient mintemp is 10 degrees C.
wbr,
Karl
Napsal : 30/01/2023 5:26 pm
Prusa Mini FW 4.5.0:
Prusa Mini FW 4.4.0:
wbr,
Karl
Napsal : 30/01/2023 5:44 pm
pmu
 pmu
(@pmu)
@karl-herbert thanks a lot! From where do you retrieve that information?
Have other Prusa printers - such as the Mk3 or even the upcoming XL - the same ambient mintemp limitations?
Napsal : 30/01/2023 6:56 pm
No, the printers do not have the same limitations. The fastest way to filter out the limitations is to read the firmware source code: https://github.com/prusa3d (see prusa-firmware).
For example, there are differences between MK2 and MK3: https://help.prusa3d.com/article/mintemp-error-and-mintemp-bed_2169
wbr,
Karl
Napsal : 30/01/2023 8:14 pm
pmu
 pmu
(@pmu)
@karl-herbert great information, thank you!
Reading firmware source code: Would love to do that! Unfortunately, I am stuck and don't know how to do that. Is there a how-to guide?
Napsal : 30/01/2023 10:32 pm
JMH714
(@jmh714-2)
Had that problem last week. I used the work-around way as I kept my sheet off the bed and start filament heat up and wait few seconds and then put sheet back on and it works.
Napsal : 31/01/2023 12:29 am
I don't know any guide on how to program or change firmware. You have to study the subject and learn the basics of C++, Linux operating system, etc..
However, simple changes of values can be done easily and recompiling is not complicated either.
https://github.com/prusa3d/Prusa-Firmware
https://marlinfw.org/docs/configuration/configuration.html
wbr,
Karl
Napsal : 31/01/2023 1:54 pm
pmu
 pmu
(@pmu)
@karl-herbert how did you retrieve the screen shots above which are showing the min temperatures?
Napsal : 31/01/2023 4:57 pm
You can find the code in following file:
Prusa-Firmware-Buddy-RELEASE-4.4.0\include\marlin\Configuration_MINI.h
Sourcecode (4.4.0) you can find here:
https://github.com/prusa3d/Prusa-Firmware-Buddy/tree/RELEASE-4.4.0
wbr,
Karl
Napsal : 31/01/2023 5:28 pm
1 lidem se líbí
Stránka 2 / 2
