Thermistor temperature fluctuations
Sid
 Sid
(@sid)
Hi All 😊聽
My Prusa Mini's have been running for hundreds of hours, but now i'm getting issues on all of them. Fan's get broken, thermistors stops working and after a replacement under warranty (thumbs up prusa support 👍 ) it's all working again so that's great. But now the strange thing i've noticed that print profiles i've been using several years now, are not consistent anymore. And I didn't understand it, it took me a really lot of time, but now I think i'm getting close, at least for a part of it.
On the printers where i've changed the thermistor I got a lot of stringing en blobs. And after a lot of cleaning and changing PFTE tubes, etc etc. I found out that it was as simple as turning down time hotend temperature by 10 degrees. To be sure it was the new thermistor i've moved it to a printer without this issue and indeed after replacement it also suffered the same issue. Reconnecting the old thermistor solved the problem.
Now I know this i can tune the temperature on the specific printers, but is there a way to setup the printer that it always retracts 10 degrees of the GCODE temperature?
Respondido : 04/12/2022 7:10 am
1 les gusta
Robert
(@robert)
RE: Thermistor temperature fluctuations
The temperature shown on display is not the same as the real temperature. I therefore always need to add +5deg to the nozzle聽 and bed values. Is there an option to "fine tune" the temperature in mimi+ firmware ?
Respondido : 09/12/2022 10:35 am
Sid
 Sid
(@sid)
No unfurtunatly not, at the moment I enter them in Octoprint as an temperature offset but this has to be re-entered every time it powered off.聽 It works but it would be better to program it somewhere in the EEPROM so it doesn't depends on external software.
Respondido : 10/12/2022 5:55 am
Zoltan
(@zoltan)
Miembro Moderator
Sid, did you do a replacement by original prusa mini thermistor?
even an old man can learn new things 馃檪
Respondido : 11/12/2022 6:18 am
Zoltan
(@zoltan)
Miembro Moderator
One possible work around can be to create a copy of the filament profile in prusaslicer and change the temperaturs
Respondido : 11/12/2022 6:20 am
Sid
 Sid
(@sid)
Yes it are original prusa replacements. Yesterday i've measured multiple thermistors, two new ones and 2聽 older ones
Unsued new 1 -> 131 k惟聽
Unsued new 2 -> 126 k惟聽
Old 1 -> 130 k惟聽
Old 2 -> 138 k惟聽
All measured next to eachother at room temperature. I don't know if this 'small' differences could be a cause of the different temperatures. Maybe they also have a different curve when heating up or cooling down.
It would be great to get more tuning at printer level. If you use one printer editing the gcode isn't a big problem, but when using multiple printers it's difficult to keep track of and a lot of work. (I sync all gcode accross my printers)
Respondido : 11/12/2022 7:24 am
Robert
(@robert)
I am using origin谩l prusa with no mods. Even a钮 the moment there are different temperature shifts on bed and head, looks the only real solution could be a fw temp_shift parameter(s). I'll try to write the suggestion/request into github. Thanks you.聽
Esta publicaci贸n ha sido modificada el hace 4 years por Robert
Respondido : 11/12/2022 11:10 am
