The nozzle on my mini, at the end of the print, has been parked in the top left corner of the bed, crashing with object printed
Hello,
why at the end of every print the nozzle is parking in the top left corner of the bed?
Of course it crash and destroy the print if some parts are there (see picture).
I'm using default settings in PrusaSlicers 2.5.1 Mac OS.
This is the default End g-code:
G1 E-1 F2100 ; retract {if max_layer_z < max_print_height}G1 Z{z_offset+min(max_layer_z+2, max_print_height)} F720 ; Move print head up{endif} G1 X178 Y178 F4200 ; park print head {if max_layer_z < max_print_height}G1 Z{z_offset+min(max_layer_z+30, max_print_height)} F720 ; Move print head further up{endif} G4 ; wait M104 S0 ; turn off temperature M140 S0 ; turn off heatbed M107 ; turn off fan M221 S100 ; reset flow M900 K0 ; reset LA M84 ; disable motors
Opublikowany : 21/03/2023 10:20 am
Topic starter
answered:
RE: The nozzle on my mini, at the end of the print, has been parked in the top left corner of the bed, crashing with object printed
Fw: 4.3.1+2759
Bootloader: 1.1.0
Buddy Board: 1.0.5
Opublikowany : 21/03/2023 10:27 am
Update the firmware. This is a known incompatibility
Opublikowany : 21/03/2023 3:33 pm
Topic starter
answered:
Thanks man; you are right.🙏
Updating the fw to 4.4.1 (and bootloader) it stops moving up with Z axis. 🏆
✅ Solved
Opublikowany : 24/03/2023 8:21 pm
