Terrible vibrations on Y axis fast mouvements
Daniele
(@daniele-2)
When printing the first layer on very fast movements on Y axis I have really impressive vibrations.
Could this be due to bad belt tension? Bad lubrification of the Y axis ball rings? Something else that comes in mind?
I’ve had my Prusa mini for 2 years now and everything has always been smooth with it till now. 😥
Postato : 05/03/2023 5:19 pm
RE: Terrible vibrations on Y axis fast mouvements
I'd start by checking the belt tension and the grub screws on the y axis motor shaft. But you may have worn out the bearings and they may need replacement. Did you regularly lubricate the rods?
Postato : 06/03/2023 1:50 pm
Daniele
(@daniele-2)
Rods have been lubricated every 100 hours of printing. The oddest part is this has started after the last time I lubed them.
Will check the belt tension and grub screw.
Postato : 06/03/2023 2:25 pm
jseyfert3
(@jseyfert3)
Posted by: @daniele-2
You didn't change the type of lubricant you used, did you?
Postato : 14/03/2023 9:54 pm
