SuperPinda and sensor info
octal
(@octal)
I installed the SuperPinda on my Prusa Mini, and when I go in the Sensor Info menu, it shows:
 MINDA 0   (zero)   when I put a gap between SuperPinda and nozzle of about 1.15mm
and
MINDA 1  (one) when I put a gap between SuperPinda and nozzle of about 0.9mm  (or 0.8mm)
Hardware: PrusaMini (Septembre 2020)
Firmware version: 4.3.0-RC1+2691)
Does this mean that the SuperPinda is not used (not detected) when the gap is beyond 1mm ???
Regards
Questa discussione è stata modificata 5 years fa da octal
Postato : 10/01/2021 9:32 pm
Gordon W
(@gordon-w)
RE: SuperPinda and sensor info
The sensor info is what the sensor is showing, not the number of sensors. So what you are seeing is normal, the bed is being detected as close to the sensor (sensor = 1) around 0.8 -1 mm above the bed.
Postato : 12/01/2021 1:01 pm
1 persone hanno apprezzato
