Stuck on firmware 4.3.1?
Prodeje
(@prodeje)
Finally assembled our mini+ from 2/2022.
It appears to have 4.3.1 firmware and 1.1.0 bootloader.
I downloaded prusa3d_fw_4_4_1_MINI.zip.  Extracted 2 BBF files.  Buddy_4.4.1+4194.bbf and Buddy_update_pre_4.4_4.4.1+4194.bbf
It seems to detect and says new firmware available 4.4.1.  I click flash and just pops up the same thing again saying new firmware available 4.4.1 and press button to flash.
I tried with both files and just 1 or the other.  no dice.  I am using the provided steel flashdrive and removed the original BBF from 2/2022.
Napsal : 05/02/2023 8:00 pm
Hello
(@hello)
RE: Stuck on firmware 4.3.1?
Maybe try contact support though live chat as it is just under warranty any longer and warrenty may expire
Napsal : 05/02/2023 11:22 pm
René
(@rene-3)
Both files must be in the root of the USB stick.
See also https://forum.prusa3d.com/forum/general-discussion-announcements-and-releases/4-4-1-firmware-for-original-prusa-mini-mini/
Napsal : 06/02/2023 8:02 am
Prodeje
(@prodeje)
Well this was an easy fix.  I was hitting the reset button instead of pushing in the wheel to select flash.  Thank you, I will see my self out.
Napsal : 06/02/2023 2:57 pm
A senior moment! 🙄
Napsal : 06/02/2023 2:58 pm
