Strange oozing
The Cutterfly
(@the-cutterfly)
Strange oozing
Hello guys! Please can somebody help me? It seems like where is this debossing it causing these horrible lines outside the print. Somebody know how to fix it? I am using prusa slicer and printing on prusa mini+. Can be the problem travel moves? the wall is also weak where is the ozing. I just don't know where is the problem. Thank you for your help
Publié : 01/03/2023 1:20 pm
Files > Save Project as
Publié : 01/03/2023 1:43 pm
The Cutterfly
(@the-cutterfly)
RE: Strange oozing
Butterfly35mm.3mf thank you. Here it is
Publié : 01/03/2023 1:50 pm
RE: Strange oozing
Your retraction seems excessive but your main problem is that the upper 4mm are just a single extrusion thick leaving no room for the slightest error.  For neat, strong, walls allow for at least three extrusions, two perimeters and a variable width filler, even then it will need fine tuning.  For ordinary prints, at around 2mm thick the slicer will give good results unaided.
Your model might be FDM printable at that scale with a smaller nozzle, eg 0.25mm, but it is a better candidate for SLA printing.
Publié : 02/03/2023 4:38 pm
