Strange issue - overextrusion
Nikomi
(@nikomi)
Hi! Has anyone had a problem with the mini that occasionally overextrusion occurs? It seems to have increased the number of steps of the extruder motor by itself. This is noticed when the filament is fed in because the filament quickly reaches the extruder and starts to slip. Excess material can be seen on the prints. When a factory reset is done, everything is fine for a few weeks, then it happens again at once. The same thing happened with the other firmware version ...
Opublikowany : 19/04/2021 6:21 am
